So I'm done with my tubing layout and my concrete guy is coming Thursday. I figured I should pressure test before he comes and have pressure in the lines when he is pouring.
I capped my manifolds and hooked up a Schraeder valve to one end of the supply manifold and pumped in 50 psi of air.
My problem is that I will not be able to tell if my tubing is leaking because my manifold is leaking like a seive. I have two Sioux Chief Branchmaster manifolds with the valves on each drop. The air is rapidly leaking out around/through the valves. I'm maybe losing 1 psi/minute, and I can hear the air coming right out around the valve shut-off lever.
Is this normal? Will the manifolds hold water or will they leak water out around the valves too?
-JR
