Help needed with system design, 2 story
Last Post 04 Oct 2010 01:31 PM by BadgerBoilerMN. 24 Replies.
01 Oct 2010 12:10 PM
Here is the Wikipedia of design (note they leave out the word Bamboozle )
No generally-accepted definition of “design” exists[1], and the term has different connotations in different fields (see design disciplines below). Informally, “a design” (noun) refers to a plan for the construction of an object (as in architectural blueprints, circuit diagrams and sewing patterns) and “to design” (verb) refers to making this plan[2]. However, one can also design by directly constructing an object (as in pottery, cowboy coding and graphic design).
More formally, design has been defined as follows.
(noun) a specification of an object, manifested by an agent, intended to accomplish goals, in a particular environment, using a set of primitive components, satisfying a set of requirements, subject to constraints;
(verb, transitive) to create a design, in an environment (where the designer operates)[3]
Here, a "specification" can be manifested as either a plan or a finished product and "primitives" are the elements from which the design object is composed.
With such a broad denotation, there is no universal language or unifying institution for designers of all disciplines. This allows for many differing philosophies and approaches toward the subject (see Philosophies and studies of design, below).
The person designing is called a designer, which is also a term used for people who work professionally in one of the various design areas, usually also specifying which area is being dealt with (such as a fashion designer, concept designer or web designer). A designer’s sequence of activities is called a design process[4]. The scientific study of design is called design science [5].
Designing often necessitates considering the aesthetic, functional, economic and sociopolitical dimensions of both the design object and design process. It may involve considerable research, thought, modeling, interactive adjustment, and re-design. Meanwhile, diverse kinds of objects may be designed, including clothing, graphical user interfaces, skyscrapers, corporate identities, business processes and even methods of designing[6].
Dan <br>BlueRidgeCompany.com
01 Oct 2010 12:59 PM
Yes, you can call anything you like design. It's even legal to do so. I believe I already wrote that in my previous posts. Twice, I think?
That said, your command of the cut and paste function as well as internet search capabilities is truly stunning. I will never question your "free design!"TM methodology again, lest you cut and paste another telling blow!
01 Oct 2010 01:36 PM
Rob,
This is a wast of my time. We supply and sell. We are a distribution business.
We have many clients, many referrals.
You want our service call it what you want, fine.
If not, Fine.
Disrespecting me, my business, my service, my systems.
Again, Best regards, I am stepping out of this thread.
Dan
papisoxUser is Offline
02 Oct 2010 02:11 PM
Can someone contact me here or off the board for design help?
BadgerBoilerMNUser is Offline
www.badgerboilerservice.com
