need help deciding ... I have 5 gutted apartments in Jersey City, NJ -- heat loss is around 15k for the small two and 20k for the larger two; and 10K for the smallest one. I want to use radiators - running at 150 max or lowers (i like cast iron but not sure they're right). I'm trying to keep my materials cost at or around 3,000 per apt. -- but could pay more if necessary.
I can either
put 5 boiler/hot water heats/combo in the basement and pipe up. (Max vertical run about 25 ft). Looked at bradford white combi, or a cast iron w/sidearm or ?
Or some kind of tankless (against code in nj, so contractors say...) solution in apartment. The triangle tube solo are way to pricey. There's the ambassador models, but i don't know about the durability (copper heat exchanger)... Then there's standard tankless stuff, but not sure about the applicability of tankless
Building a chimney is not an option -- the existing chimney can't accept a liner. Thanks so much for any advice on boilers and/or rads. (And please convince me not to cave and put hvac systems).
