jsmith6752
| 17 Nov 2010 09:28 PM |
Nice site. There seems to be a lot of knowledge exchanged. I have a quick question about slab on grade applications. I have a pole barn that is 44' x 30'. I am planning on pouring a section of the floor before the weather gets to cold. I know that if I don't install any pipe now I will kick myself later. I probably would not use the system for a few years. The first pour I am doing is 30' x 18'. My plan is to make that zone 1 . The remaining 26' x 30' will be zone 2. Would this be a major pain to do? I have not read about anyone trying this. Any thoughts? thanks jim
NRT.Rob
| 18 Nov 2010 09:17 AM |
if these are two separate rooms, no big deal. If it's one room, you can install in two sections, but you would probably just use one thermostat for both later. |
Blueridgecompany.com
| 18 Nov 2010 10:09 AM |
Good idea to get the pipe in the slab now before you pour,,, You will need to remember insulation, 2 inch rigid is the first choice, 1 inch rigid would be my second choice. As Rob says combining later is easy, or keep them isolated with 2 stats. Might see forward as to where you can place the manifold so it will be close to the manifold of pour 2. Dan |
| Dan <br>BlueRidgeCompany.com |
jsmith6752
| 18 Nov 2010 04:52 PM |
Thanks for the responses. Currently it is 1 large space. If I do ever divide the room it would be the 18' x 30' slab. I still need to figure out my pex size and layout of the piping. I was told to use 1/2" with 12" spacing. That info was basically a guesstimate from a local installer. I am guessing I will need to exit the new slab. I could use conduit were the pex will exit and leave it about a foot long so I could tie it into the next pour. Does that make any sense? I also have to find out if I should put temp sensors in. I have tried a few programs for the zone layout but have not had much luck. I am off to find another program..........thanks
jsmith6752
| 18 Nov 2010 05:56 PM |
I need recommendations for a pipe layout. I see tons of companies out there and I really don't know which way to turn....thanks |
BadgerBoilerMN
| 21 Nov 2010 04:51 PM |
www.badgerradiantdesigns.com Heat load analysis, CAD layout with tube spacing, size and number. How is that for direct...heehehee. |
