What types of flooring should be used above radiant heat?
Last Post 12 Dec 2010 06:21 AM by newsie23. 6 Replies.
cad_ilUser is Offline
24 Nov 2010 02:52 PM
Is there a list somewhere rating the types of flooring to use over radiant heat in terms of how well heat transfers through flooring material?
newsie23User is Offline
01 Dec 2010 02:50 AM
I believe that Warmboard has info on different covering (for their product).
buildgreen30User is Offline
02 Dec 2010 03:53 PM
Laminate, hardwood, tiles/ceramic should be good. Avoid carpet.
<p><a href="http://www.allpumpsdirect.com/">Pumps</a> <a
href="http://www.squidoo.com/little-giant-pumps/">Little Giant Pumps</a>
<a href="http://grundfospumps.wordpress.com/">Grundfos Pumps</a></p></body></html>
BadgerBoilerMNUser is Offline
02 Dec 2010 07:52 PM
Any floor can be warmed, but if you want to heat the average home with the floors, thinner is better.
Thin carpet (with thin pad), hardwood, cork, bamboo is great, and laminates that float have been popular for 20 years or so.
Naturally a stained concrete is the most efficient in terms of heat transfer and installation cost. Tile is a close second and on can't forget the potential for floor and walls for radiant applications.
As for the list many manufacturers have a list in their design manuals and...
http://www.radiantpanelassociation.org/i4a/pages/index.cfm?pageid=246
We have our own guide on the RPA website.
greencleaningUser is Offline
05 Dec 2010 06:51 AM
Radiant heating does not heat air directly as do more conventional forms of heating, such as baseboard convectors or forced air circulation. Radiant heat is "omni-directional." Unlike warm air, which tends to rise, radiant energy tends to travel in all directions. A large area of mild surface temperatures, such as a warm floor, is capable of transferring as much heat as a small surface area, such as a steam radiator, at high surface temperatures.
Radiant heat beneath wood flooring involves tubing in concrete, or tubing under plywood subfloors.
Here's to you, your health and the health of your family. <a href="http://www.cleaningcleaner.com">Eco friendly cleaning</a>
paulwood09User is Offline
10 Dec 2010 09:28 AM
The best wood species for hardwood flooring used in conjunction with radiant floor heating include American cherry, American walnut, mesquite, teak and oak. Quarter-sawn or rift-sawn woods
<a href="http://www.greentech.ie/"><strong>Renewable energy systems </strong></a> for all your needs
Warmboard IS a plywood subfloor (covered with aluminum) ideal for new construction, when designed 'into' the plans - running at a cooler temperature (according to the company).
People Online People Online: Visitors Visitors: 159 Members Members: 0 Total Total: 159
