Alternatives to Gyp-Crete on wood trusses.
Last Post 21 Mar 2011 04:57 PM by FBBP. 7 Replies.
16 Mar 2011 02:22 PM
What alternatives are there to Gyp-Crete on a wood truss and sub-floor? Carpet, tile and hardwood floor will go on it.
16 Mar 2011 02:36 PM
We design and spec our RHT floor panel system, Surface mount 3/4 thick, 1/2 pex.
Runs about $3.00 sq foot pipe, manifold, heat transfer plates, turns and site purchased 3/4 ply ripped to 6 inch for infill.
Glad to help should you need it.
Dan
Dan <br>BlueRidgeCompany.com
16 Mar 2011 02:49 PM
Looks like an interesting product. How about another type of poured floor?
FBBPUser is Offline
16 Mar 2011 10:28 PM
Posted By ICFconstruction on 16 Mar 2011 02:49 PM
We just used small agg. regular concrete but we had designed the floor load for this. It will crack more than gyp. If I may ask what are your reasons for not using gyp?
17 Mar 2011 07:15 AM
What I don't like about Gyp-Crete is the lack of tolerance to water. Why did you use concrete?
17 Mar 2011 09:42 AM
This is purely speculative but I'd look into using fairly thin plain concrete with PVA fibers or thin concrete covered by hardibacker (or similar) to make the surface crack free.
http://www.concretedecor.net/Abstracts/CD907-Technology.cfm
17 Mar 2011 10:36 AM
Alternate to gyp crete is what is called light weight concrete, though it weighs about 17 lbs per sq foot 1 1/2.
I have used this many times.
Mix is 7 1/2 sack portland cement, pea gravel, sand and fibermesh. pours wet, and will crack.
we get that product placed (labor & material) for about $1.50 square foot.
Place plastic on your platform before you place tubing to minimize cracking.
works well and a 2 inch line pump can handle the concrete.
Dan
FBBPUser is Offline
Posted By ICFconstruction on 17 Mar 2011 07:15 AM
I would agree with the water issue however not all gyp. products have that problem. It does depend on the mix and $$$. I used concrete because I overlay it with a stamped floor which has to much tensile strength for gyp. It will pull up a small layer of the gyp. Bob
People Online People Online: Visitors Visitors: 310 Members Members: 0 Total Total: 310
