5 Years Radiant Heat VS my old Steam heat in BTUS saved
Last Post 04 Apr 2011 02:49 PM by NRT.Rob. 7 Replies.
mikeinnycUser is Offline
31 Mar 2011 09:33 PM
Started with Steam went radiant Heat. Saved BIG.
MIKE IN NYC
BadgerBoilerMNUser is Offline
31 Mar 2011 09:54 PM
That is a shock.
Lets see. You were changing phase for liquid to vapor and back and now you heat with low temperature water. Sorry, been doing that since the 80s.
That is a shock.
01 Apr 2011 10:33 AM
bad day morgen? seems a little unnecessarily snarky.
Mike, you got anything to relate that info to degree days? that's the real "money" comparison. though what you have there is obvious enough to make a good case for your particular situation at least.
RosalindaUser is Offline
01 Apr 2011 04:07 PM
Maybe it was a DIY job - ROFLOL
01 Apr 2011 05:33 PM
Posted By NRT.Rob on 01 Apr 2011 10:33 AM
True-dat!  BTUs/year can change with the weather that year...
...and the weatherization upgrades to the building- was this the ONLY efficiency upgrade to take place during the relevant time periods?
Many 50-70 year old heating systems were overdesigned by 100-200% for the actual heat load of the building when installed, and now that the place has been tightened up, insulation & better windows installed they end up being 400% oversized or more.
It wouldn't be a surprise to find a 5x oversized antique steam heating plant would be running at only ~50% efficiency even on design day, and that a right-sized low temp system running near it's AFUE would cut fuel use by more than half.  My niece's place uses slightly less than half the fuel that it did with the almost-right-sized 85.5% AFUE cast-iron boiler + 140F baseboard system than it did with the 1920s vintage coal fired steam boiler with a 1980s vintage gas retrofit burner,  but her basement is no longer 75-80F all winter keeping the mice all warm & cozy.
Radiant and condensing would have been nice, but impossible on her budget.  Getting the burner sized correctly is huge,  modulating  load & condensing is the frosting on the cake when looking at replacing these ancient beasts.  Yet 150-200% oversizing is still rampant, even with mod-con installations (out of fear that during a cold snap it might actually get down to -120F or something?).
04 Apr 2011 02:43 PM
I am not surprised every day. I have many gravity conversions running at a third the capacity and fuel consumption of their former selves. BTW it is Morgan with an "A" Rub.
I never get that right. Sorry Moxcan.
People Online People Online: Visitors Visitors: 234 Members Members: 0 Total Total: 234
