System design question
Last Post 03 May 2011 08:42 AM by BadgerBoilerMN. 3 Replies.
media-telUser is Offline
26 Apr 2011 09:22 PM
Hi, I had someone draw this up for me for my system. I'm going to have 12 loops, with 2 6 loop manifolds in series. Please see drawing below. Am I missing anything? I was thinking I was missing expansion tank and worried about low temps returning to existing cast iron boiler. What do you guys think?
27 Apr 2011 09:29 AM
I think you missed the attachment.
RosalindaUser is Offline
02 May 2011 10:56 PM
Possible things you might need, depending on what is on the boiler side -
Expansion tank
Air Separator
Fill and drain valves
Temp and pressure gauges
Pressure relief valve
Isolation Flanges on the pump(s)
BadgerBoilerMNUser is Offline
The mixing valve will not necessarily protect a low efficiency cast iron boiler. Much depends on the load. What is the manifold hooked up to?
People Online People Online: Visitors Visitors: 264 Members Members: 0 Total Total: 264
