Dana1 I stand corrected. I mentioned HRV to control humidity when I should have said ERV. Doesn't the ERV remove some humidity? I questioned the validity of the comments in the first place as I know the minute the inside humidity reaches same as outside you are fighting a losing battle without a de-humidifier so at best this system may give you a few days of relief from the super hot humid weather. In Ottawa, we run into some hot humid spells that can last several days or more but usually there are cool dry nights where you could ventilate the ERV or HRV on high speed to change the air. Do any of these units have an option that will exchage air without moderating the temperature? I would think it would be more useful to be able to bring in cool night air and exhaust the warmer house air but NOT changing the incoming air temperature. This is useful if your wife won't let you open windows at night.
