I have hired a TECA certified hydronic designer (local requirement). Things seem to be going fine but he has called into question my desire to use an ASHP coupled with under floor panels such as Joist Trak. He claims that ASHP struggle to deliver water hot enough to work with them and is suggesting instead a 1-1/2" concrete topping system.
I thought that was the whole point of heavy aluminum extrusions - they run on lower water temps (and therefore your ASHP efficiency improves).
[Rob, I believe it was you that got me thinking this way - can you comment on Joist Trak water temperatures? I think my heat loads are minor.]
Our local building code says 5310HDD(f) and design temperature 18(f).
The house design is aiming at "code plus 50%" insulation levels, and very air tight (with HRV). 1000 sq ft basement, 1000 sq ft main floor, 850 sq ft second floor. (As soon as I have the heat loss calculation from him I will add that to the house description.)
Thanks for your input
John
