Joist Trak Installation Handbook - 2005(?)
Last Post 05 Jul 2011 05:17 PM by John7. 3 Replies.
John7User is Offline
28 Jun 2011 03:39 AM
Hi
I just need to confirm the design process in this document (http://www.uponorpro.com/~/media/Ex...sc_lang=en) which is dated 2005 is still valid.
Are there any things to watch out for when applying the chart on page 4?
I see there are two temperature scales across the bottom, one for 10*F and one for 20*F. This doesn't seem to be explained in the document. What are they?
John
04 Jul 2011 09:42 PM
Ok so Uponor contacted me and confirmed the 2005 Joist Trak installation handbook is still current and accurate.
The two rows of supply temps along the bottom the chart on page 4 are "delta T" - the difference between supply and return temps. The Uponor tech told me its basically up to the designer to choose whatever delta T he feels is appropriate. So that still leaves me asking, "how does one choose?" I presume its a combination of heat source and "designer preference".
Can anyone provide some advice or input on "delta T"?
(I am planning on Altherma ASHP and Joist Trak in "code +50%" insulated home in 18*F design temperature climate).
John
BadgerBoilerMNUser is Offline
05 Jul 2011 07:53 AM
Delta T is based on heat load and emitter output, which is mostly a matter of design temperature, again based on heat load of each room.
Thanks Badger but that doesn't really help me figure out delta T.
