Radiant combined with geo loop for shop.
Last Post 01 Aug 2011 10:44 AM by BadgerBoilerMN. 2 Replies.
fastlineUser is Offline
31 Jul 2011 12:21 AM
We have a large shop going in soon.  The decision was made some time ago to use radiant tubing at the bottom of the slab to at least assist in thermal control in the building.  We planned to use a boiler system to heat the tubing fluids but wondering if we can supplement or even mostly run the system by just circulating fluids from the floor into a geo tubing system.  Simple numbers indicate that the floor in our shop now in the midwest seems to go from about 88-90* in the summer, to 45*ish in the winter.  Since the loop temps would cover closer to the 60* mark, just getting that shop floor to around that temp should largely improve comfort.  Obviously the circulation costs is all you would have there.
I don't think this would be an issue of getting a perfect (aka, high) flow rate since we are only trying to level out the temperature from the geo loop to the shop floor.  I have not run any numbers on this but thought I might check for experience with this first.
01 Aug 2011 09:33 AM
you should probably post this in the geo forum as the actual amount of BTUs at your disposal is known to geo designers moreso than the rest of us.
on the heating side though... where are you located?
BadgerBoilerMNUser is Offline
You will have to consider humidity.
People Online People Online: Visitors Visitors: 438 Members Members: 0 Total Total: 438
