Radiant Heating
Controlling Radiant with "Aux" device of Thermostat
Last Post 27 Dec 2011 12:20 PM by
ergnut
. 4 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
jim
05 Oct 2011 11:32 AM
We're looking at getting a thermostat to run the forced air heat/ac for our entire house, and to run our HRV as well. There are some thermostats that offer the dehumidification controls built in, which is what we want. We have a radiant zone on the first floor where this new thermostat would be installed - the installer has said we could use the Aux control of the thermostat to trigger this zone. Has anybody heard of doing that? Also, do systems that combine forced air heat & hydronic ever stage these together, so the radiant is stage 1 & forced air the second stage? Thanks
NRT.Rob
05 Oct 2011 01:15 PM
you definitely want to stage the radiant 1st.
2 stage heat, yes. typically I'd use a separate dehumidistat.
jim
05 Oct 2011 01:49 PM
Is there a 'typical' logic that two stage heat pump thermostats use when deciding to go from stage one to stage two?
NRT.Rob
05 Oct 2011 03:21 PM
I don't know what you'd call typical. Some have a fixed differential (i.e. 2 degrees below setpoint) and some use PID logic (oh no I'm gonna fall short!).
jim
The new Honeywell prestige 2.0 stages the radiant first, and the differential before forced air kicks in is set to 4 degrees (max). There may be some logic that seeks to satisfy heat with stage 1 before stage 2 kicks in, beyond the temp differential, but it's not user configurable.
Radiant Heating
Membership:
croccohvacusa
People Online:
