The standard unpowered water heater tank is piped upstream of the GE heat pump water heater. I have the desuperheater of my Climatemaster heat pump piped into the unpowered water heate (buffer tank). I am looking for a circulation pump to install between the two tanks to allow the desuper heater to heat both tanks on very cold winter days and the GE heat pump water heater to heat both tanks in the spring, summer, and fall.
There's a lot of different circ pumps out there, so I'm just wondering if there are any brands I should avoid ? Or if any one with experience has a preference given my application ?
