I just stumbled across some information about the Normatherm KKH20 Passivhaus Boiler Stove and am curious if anyone in here is personally familiar with them.
"The Normatherm KKH 20 stove which has a large square
window in front of the fire, gives very little heat to the room at 1.9kW
(6,483 Btu/h) and most of the heat to water at 17.3kW (59,030 Btu/h.)
This means that you can run a Normatherm KKH 20 boiler stove in a low
energy or Passvihaus and not totally overheat the room that the stove is
in. Some small part of the heat may be needed for space heating for a
few weeks of the year but most will be used for domestic hot water
during the cooler months when the solar thermal input is that much
lower. The Normatherm KKH 20 can be totally room sealed by connection to
an external air duct and this air is thermostatically controlled to
automatically regulate the output of the stove."
Additional technical information about this model can be found here. Any idea whether or not they're available anywhere in North America
or have any intentions of being? It's intriguing technology for a
Passivhaus and completely Green. I've already contacted the manufacturer (in Germany) but have yet to hear anything back from them.
Litawyn
