Large renovation - Warmboard with Closed Cell Insulation??
Last Post 27 Apr 2012 05:45 PM by BadgerBoilerMN. 8 Replies.
petemacUser is Offline
17 Apr 2012 09:10 PM
Hi folks,
This seems to be a really active forum with some excellent participation.
My wife and I are in the process of buying a ranch in NJ and are planning to reconfigure the 1st floor, expand either the rear or front of the house and add a second floor.  In essence we're hoping to create our dream home.  We'll almost have a blank slate to work with but we'll need to save some walls so that it's technically considered a renovation and not a new construction (for tax reasons).
To me, this is the only real time we can take advantage of newer, more efficient technologies like radiant heating and top of the line insulation.  This is where I'd like your input.
1.  The sub-floor of the 1st floor looks like slats of wood running diagonal to the floor joists (this is from looking up while in the basement. I wonder whether this is substantial enough to leverage the Warmboard-R, which is their non-structural product line.  Thoughts?
2.  Let's just say that I decide to rip it up.  Typically the subfloor runs underneath the bottom plate of the walls (right?).  Can I just run an edge saw along the bottom plate to separate it from the rest of the subfloor, then lay Warmboards down?
3.  If I choose closed-cell insulation, would I ever see the return on investment for Warmboard/radiant heating, or would it be overdoing it?
Thanks in advance for your insight.
--Pete
17 Apr 2012 09:12 PM
you never see return on investment for radiant. you do see a major comfort improvement in most cases and some improvement of efficiency. maybe not if you're building an "ecobox" but if you're retrofit'ing then you'll probably notice the difference.
Greg PineUser is Offline
20 Apr 2012 09:25 AM
Good morning Pete -
I am the Regional Manager for Warmboard covering (and residing) New Jersey; please feel free to contact me at [email protected], I would be happy to answer any questions you might have about Warmboard and learn more about your project.
I look forward to hearing from you.
Greg Pine
Warmboard - Regional Manager
GTJONUser is Offline
20 Apr 2012 12:22 PM
Greg:
I have been notified to not use eM's and marketing here.
Was very excited to show named differences, but ALL want to do that.
Seems pointing to another for advice is accepted if not you directly.
P:
Contact G.
I have to agreefor a lot installed radiant: NR, can give an example I bet, too.
There is no payback if Peace of Mind does not help, especially wanting comfortable walkways under bare feet.
Some under designed radiant has UNCOMFORTABLE TOO HOT spaces in walkways you do not want floors and barefeet to meet.
if ROI is all that is called EFFICIENT on the called carbon footprint from phone use to planning to all driving cars and trucks to acquiring a system running and balanced --- all energy -- for radiant -maimly- heating... I have some more Q's.
A needed radiant app: M Bath and Bed; Kitchen/dining and a little in other baths and very little in basement slab as it uses MORE Btu's/sqft, even well insulated, than so many warm air directional supplies pointing at a floor area in winter, creating warm feet in a rec areas sitting room. But if it is bean-bag bedding sown there, you may have seen /felt- floor radiant is really 'cool', I mean warm, I mean cool, too.
If ducting
and under desired radiant heating areas or the others un-tubed if having 30% joist radiation or something,
- can be accepted with highest grade UNINSULATED flex in joists, the powerful variable blowers today handle more friction such that 25 ft 6" flex works fine on a 10x4 or 12x2.1/4 register blowing well enough, adding a run or 2 more runs in a large zone. and set to produce 98-deg air at today's programmed systems, RADIATES to very noticeable comfort through flooring systems .
Better installers pointing to
Better building
Better Insulation and better distribution, filtering,
destratification ( that of all I have measured by temp on extensions: RADIANT HAS OF SOME NEED)
(( no radon)) sealed ducting, -all-
Tiny powered HVAC
Heat-Recovery to HW and 100% longer payback save the most in 9-10 years (usually fam of 4 or more)
then
get your 1st mo bill and re-shop supplier rates.
24 Apr 2012 02:44 PM
Posted By petemac on 17 Apr 2012 09:10 PM
Hi folks,
--Pete
There's no cash return on radiant floor, but where and how much you put the closed cell foam can make or break the cost-effectiveness of the foam.  Putting R6/inch insulation inside of stud bays is essentially money wasted if you have other means of air-sealing the wall. The R1/inch thermal bridging of the ~20-25% framing fraction dominates the heat loss of studwalls built that way.
In a 2x4 studwall with a 25% framing fraction you could have R-infinity (made from Unobtainium? :-) ) for the center cavity R-value, but the average value for the whole wall with the thermal bridging of the framing factored in would be ~R15.
In a 2x6 studwall with 25% framing fraction with  R-infinity cavity-fill delivers only ~R23.
A  25% framing fraction 2x6 studwall with 5" of closed cell foam in the bays delivers ~R15.
But if you did a 2x4 wall with cellulose fill and put 2" of closed cell (or rigid polyiso) on the exterior of the sheathing, thermally breaking the studs with R12 foam you'd have an R30 wall at the same thickness as your R15 closed cell 2x6 wall, for about half the insulation cost.  This is a reasonable stackup for carrying some ROI for a NJ climate if you're heating with propane, electricity, or oil, but is about the limit of what makes economic sense for heating with condensing gas.
If you use reclaimed roofing iso (from commercial re-roofing and demolition) over the sheathing rather than virgin-stock there's an argument for going with 4" even with condensing gas.
If the foundation walls and band joist are not currently insulated in the basement there's a long term economic argument for 2" of closed cell foam there too, but 3" of EPS with the edges foam-sealed would usually be cheaper, or 1" XPS trapped to the foundation wall with an R11/R13 batt insulated studwall.  On any new foundations under additions, a minimalist R16 insulated concrete form approach is usually reasonable, if not, insulating on the interior with foam is.  There's an argument for about two inches of EPS under any new basement slabs too- add an inch of XPS over that if you intend to make it a radiant slab.  XPS retains the staples used for holding the PEX better than EPS does, but is a bit more expensive per unit R. With 2" EPS and 1" XPS you'd be at about R13 under the slab, which makes sense for heated slabs, whereas R7.5-8 is fine for slabs not being used as radiation for the heating system.
26 Apr 2012 01:12 PM
What are you looking at to make the HW in needed radiant area?
Rem:
Just like D1 other mentioned Mini-Splits,
HOW you distribute air (a/c ducting to registers)
CAN make a ROI more apparent with some warm air direction to conditioned floors.
The COOLING seems to need little if any adjustment.
Air stratification is removed if you are also FILTERING with the HVAC unit
JP
www.GEOPros.org Ht/Cl/HW recovery One System
BadgerBoilerMNUser is Offline
27 Apr 2012 05:06 PM
Every proper radiant floor design starts with a heat load analysis performed by an experienced radiant floor designed on dedicated software. Once you have the heat load, the boiler and emitters (radiant panels) can be considered. Before the load is secured, all is conjecture.
27 Apr 2012 05:20 PM
Thanks everyone for your feedback and input. Not sure I understand what framing fractions are, so I guess I'll need to do some Google searches this weekend! I doubt we'd go with a mini-split design due to its aesthetics. The rest will all depend on the $$. Once our architect finishes with the drawings we'll need to send out RFPs and reassess our available budget, and have someone qualified perform a heat load analysis.
Now your talking! Architects should, but it seldom it seems, perform a proper heat load. Here is what it looks like:
Attachment: Steel_Building_Radiant_Floor_Heating_Sample_Lo.pdf
People Online People Online: Visitors Visitors: 418 Members Members: 0 Total Total: 418
