Posted By pwalk on 27 May 2012 03:28 AM
Thanks for the replies. Mine is a Resol (caleffi) as well. Looks solid.
Anyone used an Ecobee system with Radiant? Just read a little about them.
I haven't used the Ecobee t-stats with radiant probably because the houses i usually do (these days) are radiant throughout and therefore suitable for outdoor reset only based on supply/return water temp. Sometimes a high limit sensor is on the wall.
Totally different story when there are multi-zone systems. A fancoil would be on a different outdoor reset curve but and would have a t-stat, usually a standard Honeywell programmable.
