There is no such thing as zero, (even solid crystals carrying no electric current have a magnetic field.) The DC magnetic field at the surface of the earth is ~0.4G, give or take ~0.2G depending on where it's measured.
I've measured many things with VLF/ELF field survey meters, but never resistive electric heating products. Products that use non pulse-width modulated DC current will have much lower ELF/VLF than AC output with thyristor-dimmer or rectified diode waveforms, but the power supply that's delivering the current could be a real VLF/ELF blaster similar to fluorescent ballasts, with significant VLF/ELF emissions on the control cabling to the thermostats, etc, even if power to heater elements is "clean".
In Thermosoft's statement #4 on their
website:
" ThermoTile radiant floor heating systems are manufactured, unlike any other heated floor system, with both a current return wire AND an inner foil wrap to eliminate EMF risk."
...belies a misunderstanding of what it takes to mitigate low frequency EMF. A foil wrap does next to nothing against EMF/VLF emissions due to woefully insufficient skin depth at the wavelenghts/frequencies of interest. While foils can mitigate radio frequency stuff, they're worthless at sub-megahertz frequencies, let alone 60Hz/120Hz and the single digit harmonics thereof, which comprised the vast majority of the emitted power in powerline EMF. The drain wire is similarly useless. The picture on their web page (http://www.thermosoft.com/radiant-floor-heating/ )may or may not be accurately depicting the actual product, but it shows un-twisted wire inside the foil shield, and twisting the conductors would be EXTREMELY effective for making the emissions fields self-cancelling at ELF/VLF frequencies beyond some minimum distance (determined by the tightness of the twist.
Their statement:
"This eliminates interference with telephones, radios, pacemakers, hearing aides and television. Without these features, other electric floor heating systems can act as a huge static-causing antenna under your heated floor."
...makes me believe the thing is actually PWM or cheap thyristor dimmer output, a sewer of emissions from 60Hz-500MHz. The foil will mitigate some of the emissions the 10+ MHz issues related to communications RF, but as stated, nothing much in the sub-1MHz region, and absolutely nothing at power line frequencies.
Bottom line, request independent 3rd party field test data of the ELF and VLF from the manufacturers. (Get a spectrum with decibel milli-gauss, if they will provide it.) It may in fact be as low as stated in the powerline harmonic spectrum, but there's nothing in their promotional statements on the topic that leads me to believe they have better than a 5-th grader's understanding of the problem.
If you really care about this, use a hydronic (pumped hot water) solution, and place all pumps, power wiring and hot water heating devices in a location well away from the floor being heated.
