electric radiant troubleshooting
Last Post 07 Mar 2013 07:22 PM by BadgerBoilerMN. 3 Replies.
05 Mar 2013 11:06 AM
I have permatherm electric radiant cable heat on concrete slab, self leveling, then tile. Worked great for a few yrs then now, keeps tripping off when trying to turn it on. Are there problems that can develop with cables over time? (hope not!) Or would it be a controller/thermostat issue?
05 Mar 2013 12:20 PM
With a ohm-meter (or milli-ohm meter) you should be able to tell if there's a dead-short on the element cables, base on their rated power and operating voltage.
warmsmeallupUser is Offline
07 Mar 2013 11:49 AM
Make sure there is no short to the ground lead from either element lead. Then call the manufacturer to find out what the ohm's reading should be for the element you installed. Then check the reading between the elements to be sure it's within 5% +/- of what the reading should be.
<a href="http://www.comfortradiant.com" target="_blank">COMFORT RADIANT HEATING, LLC</a><br> <a href="http://www.comfortradiant.com/zmeshinterior.php" target="_blank">Floor Warming</a><br><a href="http://www.comfortradiant.com/roof-deicing.php" target="_blank">Roof De-Icing</a><br><a href="http://www.comfortradiant.com/snow-melting.php" target="_blank">Snow Melting</a>
BadgerBoilerMNUser is Offline
I have never had that problem...my bad. hehehee
Nice to hear from you again warms.
