Radiant heating in smaller less used spaces?
Last Post 08 Mar 2013 12:17 PM by Dieseltwitch. 4 Replies.
BrianUser is Offline
08 Mar 2013 09:36 AM
I'm in the process of building a new house 2,000 on the main level and another 1,500 in the basement. I'm wondering the best way to deal with things like bathrooms and laundry rooms. Should I zone the them separate from the adjoining haul or room? or zone them all together? I mean most of the time the doors are open so heat the temperature will stabilize... I think. Look for some advice
$50/hr if I do it, $75/hr if you watch, $100/hr if you help!
ICFHybridUser is Offline
08 Mar 2013 11:26 AM
Unless you have a heat loss problem in that room (bad windows, sealing, insulation or exposure) you shouldn't have to make it a separate zone. If you can't get over the thought, what I did is make it a separate circuit with a flow adjustment on the manifold so I can (manually) make adjustments with respect to the other rooms in that zone.
sailawayrbUser is Offline
08 Mar 2013 11:33 AM
We typically have a separate zone for master bathrooms because some people like to have a higher bathroom floor temp than normal room floors. This can be properly accomplished in the design by considering the required heat gain for the bathroom and adjusting the tube spacing to get the desired floor temp. For a laundry room, it sort of depends on where it is located in the house. If it is located in wing of house where the bedrooms are located (which is the best location given that is where clothes are kept), we typically just include it with one of the bedroom zones or hall. If it is located in perhaps an air chambered mud room entry area, it might make sense to have a separate zone to allow operating at a lower temp. Presumably you will be using manifolds with balancing values to allow making minor temp adjustments as desired.
In a small building it is usually best to try to minimize the number of separate zones that will be operated at vastly different temps because this may require you to isolate floor/walls to fully achieve. In a small building one can often design a system that uses a common boiler supply temp for all the zones and avoid complexity of mixing valves. We have free software on our website to evaluate doing this. However, we would not consider your building small.
08 Mar 2013 11:45 AM
you need a room by room load calc and floor covering analysis to know how rooms perform. there isn't a shorthand answer for all rooms. as a rough rule of thumb, the more time you spend in a room the more you should care. a powder room may not be of concern. master bath is. Laundry, depends on what you're doing in there other than stuffing cloths in the washer. are you folding? sorting? etc. but once you've established what rooms you care about, you still need the calcs to determine what rooms work well together.
This actually Helps a lot. I like the idea of just using flow control valves to adjust each little room. Im using warm board so adjust the spacing isnt going to really work here. Im not done drawing the house to do a load calc on each. I will once we get closer the the final plan point.
People Online People Online: Visitors Visitors: 221 Members Members: 0 Total Total: 221
