One boiler. We design and install radiant floors using electric boilers including Electro and Thermolec. The smaller the load the less important the staging or ODR in terms of comfort and efficiency. For a temporary application, neither makes sense. Many of our radiant systems, both gas-fired and electric, modulate output on outdoor temperature and range from 70 to 95°F. Just finished a radiant ceiling retrofit designed to 100° DWT, running off an existing cast iron clunker, but ODR will be retrofit. Pumps normally cycle with the boiler, but full time pump can be used depending on the design. We use ECM pumps on many designs. Three electric boilers? Three expensive installations. They make zone valves and manifold actuators for this. The electric boiler is just a tool. The trick is designing a system around them. The question is really; how to design a radiant floor heating system? |
