Posted By ronmar on 17 Dec 2015 12:10 PM
Well foam designed for use under concrete should be high density(>25PSI?). I can walk on 25PSI and it barely leaves any indication of my boot treads. I think it would survive after the sand and pavers are in place to absorb/distribute the force. You could always make up a test walk/pad to experiment with some high density foam to see what effect the compactor would have on it...
Yes, CreteHeat is available in 40 and 60 psi, but have no concept of what that really means in terms of plate compactor force. Also, I don't want to overbuild, if not necessary, and I don't want to repeat experiments others have already done :)
