Roth Panels
Last Post 04 Aug 2016 04:44 PM by sailawayrb. 2 Replies.
RGatesUser is Offline
21 May 2016 03:32 PM
Has anyone used Roth panels as an above floor panel system? The home is new construction, full basement with radiant in the slab. The basement will be unfinished at this point but who knows what the future will bring.  Putting the tubing in the concrete now is a no brainer. I have looked at numerous above floor systems, listed from most to least expensive, Warmboard, Rehau, Roth, Sunboard , the various plate systems and the joist track, quick track and what ever other track systems LOL. I will be purchasing one of the preceding systems. I was thinking about Roth on the first floor to take advantage of the insulation in the panel to help with downward heat loss to the basement. If you put any credence in the infamous Virginia tech study the Roth panel performance was second to the Rehau raupanel at 1/2 the cost.  Here is a link to the study.
https://www.google.com/url?q=https://theses.lib.vt.edu/theses/available/etd-01182006-011730/unrestricted/Performance_Test_Protocol_for_Radiant_Floor_Heating.pdf&sa=U&ved=0ahUKEwjUsfK78-vMAhUHJR4KHQ_VA5QQFggFMAA&client=internal-uds-cse&usg=AFQjCNEk-tpI6_u0fh9CQqj1jZwmxCo1NQ
Any input would be appreciated.
Ron
CreathermUser is Offline
04 Aug 2016 11:05 AM
Man, got on here too late. You should check out www.creatherm.com. Our panels are used for the slab and our quality is superb.
sailawayrbUser is Offline
Really...you are going to dredge up old posts just to advertise you products... How about you actually contribute to the forum or get lost.
People Online People Online: Visitors Visitors: 497 Members Members: 0 Total Total: 497
