Radiant Heating
Using line voltage thermostat to power circ pumps
Last Post 02 Dec 2016 08:10 AM by
PressureTankFrank
. 3 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Poyse2b3
26 Nov 2016 09:48 AM
Hi everyone I am building a simple garage radiant floor system and I was wondering if it is ok to use a line voltage thermostat with a floor sensor to power the circulator pump when the system calls for heat instead of a 24v thermostat wired through a switching relay. Thanks!
PressureTankFrank
01 Dec 2016 11:28 PM
What pump are you interested in? I don't think you can do this.
GEEZER
02 Dec 2016 05:59 AM
That's what I'm doing right now. Using a Honeywell TL8100 connected direct to my pump. Works good.
PressureTankFrank
I may have read your post wrong. I thought you were asking if you could power a pump with 24 volts. Yes, with radiant heat, you can buy line voltage thermostats which connect directly to your pump.
Radiant Heating
Membership:
croccohvacusa
People Online:
