Rotting subfloor with under floor pex
Last Post 14 Feb 2017 02:46 PM by 3cityblue. 2 Replies.
NesnahojkUser is Offline
12 Feb 2017 11:36 PM
I have a rotten subfloor on the second floor. There is radiant pex underneath. Can I replace the subfloor without ripping up the ceiling below?
ronmarUser is Offline
13 Feb 2017 08:05 PM
If it is attached to the subfloor, I don't see how you can avoid it, at least to be able to re-attach the tube to the new subfloor.
3cityblueUser is Offline
Surprised that there was no evidence of moisture on the 1st floor ceiling to begin with. How did you determine you had a subfloor problem? Spongy area around a toilet or something? You might be able to avoid a ceiling tear out if it is a localized problem area around some type of plumbing penetration.
The radiant tubing may have been run to avoid, say, a waste piping penetration. I'd start with a small subfloor cutout to try and get a peek of what I was dealing with. Might get lucky, otherwise, at least some ceiling will need to come out.
People Online People Online: Visitors Visitors: 528 Members Members: 0 Total Total: 528
