Hey All,
I've been meandering down the path of lots of different space conditioning systems.
The one I keep coming back to, the claimed "Rolls Royce" of conditioning, is radiant.
We have an existing home that currently heated with scorched air and cooled with a 5 ton single stage unit.
While it certainly works and I do plan to keep it, the engineer in me wants to look at other more comfortable options.
I've been playing with Wrightsoft a lot to dial in all my numbers for my manual J and so far I have:
34,026 BTUh Heating Load
36,115 BTUh Cooling Load
https://drive.google.com/open?id=1nweso6DsIeLX1X4LODI2Gd2XyqxVpnKi
The only thing that I don't have a hard number for yet is my blower door test results. I'm finalizing some air sealing before I get that done, but I'm almost there.
As I make improvements to the house (like upgraded windows) I've been updating the manual J.
I'm interested in hydronic cooling and heating. Given that this is a retrofit situation I had planned on doing a radiant ceiling.
This product seems to be where it's at for radiant cooling:
https://radiantcooling.com/
I've reached out to a local supplier, but I fear the costs of that solution. It looks pretty neat though!
I know one of the biggest issues with radiant cooling is dewpoint control. With the Messana solution they have their own proprietary control system that will handle all the zoning and dewpoint.
I found that tekmar also has an available solution to do the controls for this setup, very interested in this one:
http://www.tekmarcontrols.com/products/alternative-energy/406.html
I plan to use a chiller like a Chiltrix or Spacepak for the cooling side of the hydronics. On the heating side I have an HTP Phoenix Light Duty water heater that I plan to use for my heated water source.
My first, main question is do you guys have any advice around radiant cooling products that aren't the messana product?
Could I use something like the warmboard-r/ecowarm products for cooling?
Alternatively I was considering DIY-ing my own messana panels using three layers:
1/2-in rigid foam
plywood and aluminum fins (https://www.radiantec.com/product/single-groove-aluminum-heat-emission-fin/)
1/2-in drywall
Not sure it'll be any cheaper, need to run the numbers, but in theory it could work?
Lastly, the biggest motivators here are #1 comfort, #2 zoning, #3 efficiency.
We have plenty of solar (10.89kW DC) to cover our existing loads with no issues.
P.S. I'm sure Dana has seen a lot of this information from my ramblings over at Terry Love's forums, so sorry for the repeat :)
