Need individual zone controller?
Last Post 29 Apr 2019 08:43 PM by Dana1. 3 Replies.
mbewley59User is Offline
27 Apr 2019 07:12 PM
I'm installing a small (1000 sq ft) closed loop system for my cabin and want to avoid buying the pricey Taco-type control units. I'll have 5 zones and want to be able to open their individual valves only as long as it takes each one to have its water completely exchanged.
Q: Could I use individual temp sensors on the return lines to close the valves for that zone? I'd set up an Arduino-type microprocessor programmed to open all zones to start when the circulator pump is turned on, and then close close them each as their return lines reach a certain temperature. This a good or bad idea?
sailawayrbUser is Offline
28 Apr 2019 04:01 AM
Well, it is certainly possible to do what you propose using a microprocessor and electromechanical solenoid valves, but I am not sure I understand why you would want to do so. The actuators and zone valves normally used on HR manifolds to open and close the PEX circuits accomplish this by heating a wax cylinder that than expands to open the valve. This approach uses way less electricity and is extremely reliable for the many cycles that occur over the lifetime of the HR system. The control modules sold to operate these actuators and zone valves as requested by the thermostats also communicate to the pump and heat source so everything is well coordinated. So I think you are trying to solve a problem that doesn’t exist or has already been solved.
newbostonconstUser is Offline
29 Apr 2019 04:12 PM
I tried this type setup on my old house. Certainly is a fun project but there are easier proven ways.
I would buy a 5 zone manifold with everything pre plumbed(valves, flow controls, and temp probes), then use a thermostat and a relay to turn on the pump.
Sounds like you might be using potable water because you are stating you want to purge it. Most don't support using potable water linked to radiant floors. It is even worse in a cabin that isn't used all the time.
It can be done in a house with some loop configurations that constantly flush the water.
How are you planning on heating the water?
I can't quite wrap my head around the rationale for installing five micro-zone for a 1000 square foot cabin rather than running it with just 1 or 2 zones.
What makes that level of complexity "worth it" for somebody who finds the expense of a zone controller "pricey"?
Is this an off-grid application, where every milliwatt-hour matters?
People Online People Online: Visitors Visitors: 157 Members Members: 0 Total Total: 157
