I'm installing a small (1000 sq ft) closed loop system for my cabin and want to avoid buying the pricey Taco-type control units. I'll have 5 zones and want to be able to open their individual valves only as long as it takes each one to have its water completely exchanged.
Q: Could I use individual temp sensors on the return lines to close the valves for that zone? I'd set up an Arduino-type microprocessor programmed to open all zones to start when the circulator pump is turned on, and then close close them each as their return lines reach a certain temperature. This a good or bad idea?
