Hello all, newbie here... I am trying to decide what percentage glycol to use in my hydronic radiant heat system?
I am in central Virginia, have two Chiltrix air to water heat pumps, indirect DWH, 20 gallon buffer tank for the radiant supply.
We have 2200 sq ft of concrete on a slab and the same in an upper level, both with 1/2" pex throughout.
Is there a formula that should be used for calculating the percentage glycol? Should I consider not using glycol?
And, any thoughts as to the best place within a 100 miles or so of Richmond to get it?
fyi... in the event of a power outage in the winter, I would fire up the generator... but if for some reason the generator would not start, I would be stuck and would not be able to circulate the water. I have a great fireplace that is capable of heating the entire house, new build that is very tight... but the Chiltrix are still in the elements...and would freeze.
Dean
