Help: Aube Heated Floor Thermostat Won't Stop Heating
Last Post 05 Feb 2021 02:04 PM by newbostonconst. 2 Replies.
Author Messages Not Resolved
MyFloorIsTooHotUser is Offline
04 Feb 2021 12:08 AM
I'm having an ongoing issue with the heated floors in my apartment, which are controlled by the following thermostat: Honeywell Aube Non-Programmable Thermostat 240V DPST (TH114-A-240D-B).
The thermostat never actually stops heating. That is to say, if I set the thermostat to 20.5 degrees (C), it'll just keep heating, regardless of what temperature the floors and apartment reach. It clearly registers that the temperature is rising, far beyond the set temperature.
Here's a quick sample video. Note how the thermostat correctly indicates that it's an insanely hot 23.5 degrees, even though the thermostat had been set consistently at 20.5 for hours.
I understand the theory of a thermostat overshooting its target, in the name of oscillation. But regardless of the many combinations and strategies I've tried over the past months, it seems like this system will never actually stop heating, as long as it's turned on.
Is this expected behavior for such a unit?
(Side note: You may say this is something I should talk to my landlord about. Unfortunately, my landlord is - shall we say - less than awesome.)
Thank you for any and all help. It's such a shame when this system get too hot, and I have to open a window in the middle of Feb. Sorry, Earth. :(
Chris
ChrisJUser is Offline
05 Feb 2021 01:08 PM
Can you turn it off?....Turn it back on when temp drops Hello landlord, my tstat is broken, heat running constant costing you money! Unless you pay for heat then all the more reason to get it fixed.
newbostonconstUser is Offline
Likely wired wrong....There are heating and cooling forums that can likely help you better.
Need picture of the wiring.
