Paul, welcome to the forums. We welcome your input. Sounds like you have some good experience to share.
Posted By Paul Auerbach on 02/13/2008 11:34 PM
Water based closed loop systems are less efficient because of the pumps to drive water for the heat transfer. They're also prone to failure. At least that's our experience.
Paul Auerbach
Managing Partner
Total Green LLc
I am not sure what you mean by this, but it is simply not true. We have been around water source heat pumps for years. We have seen hundreds of installations. We have never seen one fail on it's own if it has been designed and installed correctly. Certainly if the product is not installed properly or not used in the manner it was intended, then there can be problems. The same can be said of DX systems.
This forum is not a place for one guy to bad mouth the competition. I hope you understand my concerns.
