Geothermal Heat Pumps
Cutting my heating bill
Last Post 18 Feb 2008 07:26 PM by
geodean
. 3 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
TechGromit
18 Feb 2008 03:56 PM
I've been told that insulating my basement would save between 20k to 27k BTU of heat loss. My initial response was doubtful, since the basement isn't heated anyway. When I thought about it, since the basement is cooler than the 1st floor above it, it would tend to cool off the first floor faster then it should. I know that 20k BTU is just a rough estimate, but is there a formula I could apply to figure out what my actual BTU heat loss currently is. I would think that a 10 x 20 foot uninsulated basement would have the same heat loss per sq foot as a 20 x 50 uninsulated basement. And number two, how much can I expect to save per 1k BTU heat loss if I insulated the basement. This would give me a cost / benifit ratio I can use to justify the expense of insulating.
Palace Geothermal
18 Feb 2008 04:35 PM
Attached are two heat loss calculations from a house. The first has no insulation in the floor. The second has R 30 in the floor.
As you can see the difference is about 20k BTUh.
This is for total floor footage of 2700sqft.
1 kw is about 3400 BTU. If your heat pump has a COP of 3 then you get about 10k BTUh for each kw you buy. So based on your kw rate, you can figure your savings.
Hope this helps.
Attachment: no floor insulation.pdf
Attachment: with floor insulation.pdf
TechGromit
18 Feb 2008 07:23 PM
Thanks for the PDF files! Over what period of time are these figures for? Daily Averages?
Thanks!
Palace Geothermal
These are BTU's per hour at the design conditions listed at the top of each report.
This particluar house was designed for an outside temp of -10° F. So when it is -10 the heat loss will be what is listed on the report.
Membership:
croccohvacusa
People Online:
