Ciculating pump
Last Post 22 May 2008 12:23 PM by firefighter1819. 6 Replies.
firefighter1819User is Offline
22 May 2008 11:34 AM
hi everyone i am a new member from michigan and i am installing a geothermal system into my personal residence
i purchased a 5 ton Heat Controller brand furnace (HRH060) and hope to order my slim jim for my pond this week
the thing i cant figure out is how the heck the circulating pump gets wired into the system so it knows when to turn on and off?
with a closed loop system it doesnt seem like i need any type of automatic valves or anything just need the ability to turn the pump on and off.
how does everyone elses work?
does the pump get AC power from the fuse panel and have some kind of dc switch built in that gets activated by the furnace?
22 May 2008 11:49 AM
I am nor familiar with your brand.
On most heat pumps you pull power for the circulating pumps from the compressor relay inside the heat pump. That way when the compressor kicks on the circulating pump starts up.
Hope this helps
22 May 2008 11:50 AM
so this is all of the power for the pump to run, i assume that this is going to be 120 VAC right?
22 May 2008 11:51 AM
what is the best pump?
22 May 2008 11:57 AM
Posted By firefighter1819 on 05/22/2008 11:50 AM
If your heat pump runs on 220V then you need a 200V circulating pump.
We buy our circulating pumps here.
22 May 2008 12:12 PM
i think the name on the furnace is actually comfort-aire i listed the manufacurer name earlier
hey those are really nice looking units will they help me to size the pump for my run
i am going to have 400' of 1 1/4 running to and from the 5 ton slim jim heat exchanger
People Online People Online: Visitors Visitors: 534 Members Members: 0 Total Total: 534
