DX Grout
Last Post 26 May 2008 10:27 PM by Alton. 8 Replies.
pjc57User is Offline
25 May 2008 12:17 AM
How come DX systems don't have to be grouted?
25 May 2008 09:59 AM
Where did you get that idea? DX boreholes absolutely need to be grouted.
25 May 2008 02:18 PM
PJC57,
Maybe you are thinking about horizontal DX systems not being grouted.  All wells, regardless for what they are use for, should be grouted to protect the underlying aquifier.
25 May 2008 11:31 PM
Hi Guys,
This is where I got the idea.
http://www.copper.org/applications/plumbing/heatpump/geothermal/cs_stdy_pa1.html
I believe they just backfilled it with sand and water.
25 May 2008 11:49 PM
When there is no aquifer involved, it may be legal to backfill with sand and water. This will result (when done properly) in a perfectly functional DX well. However, it's still a better idea to grout the hole with a thermally enhanced grout. Mostly, it's a legality issue with aquifers, though.
26 May 2008 09:13 AM
PJC57,
Thanks for the reference to the web site about the DX system.  The fourteen holes 50' long drilled at a 30 degree angle is actually only 25' deep.  In most areas, this would be considered a shallow well.
26 May 2008 09:01 PM
Alton,
I believe that the 30 degrees is off the vertical, putting the depth at about 43' deep.
26 May 2008 09:09 PM
Yes, it's off the vertical.
Thanks.  Off the vertical would make a difference.
People Online People Online: Visitors Visitors: 473 Members Members: 0 Total Total: 473
