Status Light
Last Post 16 Jun 2008 01:45 PM by TRI-L. 4 Replies.
davarUser is Offline
14 Jun 2008 09:44 PM
Hello. When I went to start my waterfurnace premier for the first time in a month, nothing happened and the status light is blinking.I shut off the breaker  and turned it on again and it does the same.Anyone got an idea of the problem? I will call the service center Monday but just wondered whats wrong.Thanks
14 Jun 2008 10:51 PM
Satus light blinking is normal for my Envision. Envision is closely related to Premier. My guess is your unit is not getting "calls" from thermostat or zone controller
fsq4cwUser is Offline
15 Jun 2008 01:27 AM
Before you call for service, do the logical things, like check or replace your air filter, vacuum the air heat exchanger & clean your condensate drain.
SR
15 Jun 2008 09:32 AM
Those suggestions are all good but none of them will cause a unit not running to run
TRI-LUser is Offline
IF you have Internet access LOL. Go to Waterfurnace.com and down load owners manual, go to page 35.
