We will be building a home in
eastern Tennessee. The area is heating dependant on the Cumberland Plateau.
I would like to use a geothermal heat pump for heating and cooling
needs. However, our building lot has
some significant limitations, the first being the depth to bedrock averages
about 42” across the lot. I do not
believe that the ground freezes, so there is not a freeze line to worry
about. I have ask a couple of well
drillers in the area about drilling bore holes and all have said that they had
drilled boreholes in the past for geothermal systems, but would not give me any
idea regarding prices for drilling bedrock.
While I know that there are a lot
of variables involved in the construction, we are planning to use SIP’s for the
walls and roof. The topography may allow
for a walk-out basement which will have 6” to 8” poured walls on an insulated
slab.
My questions are as follows:
1. Is it feasible to drill through the
bedrock? I assume that I will need
several holes for the vertical loop.
2. Based on the approximate size of the home
(approx 64,000 cf of conditioned area) and garage (18,000 cf of partially
conditioned area) what number of bore holes would be needed?
3. While I know that every job is
different, what is the typical cost per foot of drilling the bore holes?
4. Is the depth to a water table critical
for geothermal, as I plan to use a closed loop system.
