Geothermal air conditioning
Last Post 02 Aug 2008 01:24 AM by Dan CGD. 1 Replies.
SeanUser is Offline
31 Jul 2008 04:39 PM
My wife and I are in the design phase of our retirement home.  We intend to use geothermal hydronic in floor heat.  The floors will be 3/4" hardwood.  I understand that I cannot use the geothermal system to provide cooling under the flooring.  I was contemplating utilzing the cool geothermal liquid by pumping it to the indoor units of a split air conditioning system.  Will this work?  Are there any difficultys that I should watch out for?
Thanks for the help.
Dan CGDUser is Offline
This will work just fine. Actually all you will need to do is utilize small air handling units with water coils. I believe Terratherm is a unit that some of our clients have used before. Do a little digging and you'll find that this is fairly common practice. I have also heard of the small minisplit units being used, but be careful on sizing and air noise. I leave most of this up to the HVAC guys. We just install the loopfields. Hope this helps.
Dan
People Online People Online: Visitors Visitors: 489 Members Members: 0 Total Total: 489
