Geothermal Heat Pumps
Pond loop with Slim Jim
Last Post 14 Aug 2008 11:22 PM by
Alton
. 3 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
ptfd1819
14 Aug 2008 06:19 PM
i am currently installing a slim jim pond loop in my personal home, my question is can i run pvc sched 40 piping inside of my house rather than the HDPE
i want to run the pipes along the wall in my garage in order to get into the equipment room
i think i can more easily strap the pvc to some quick strut than i could the HDPE also is would be less prone to damage via the kids
i would want to run the pvc into the pump panel
does any one see an issue with this?
Palace Geothermal
14 Aug 2008 08:48 PM
We have used PVC for inside piping before. The only issue we had was a few leaks at the transition from HDPE to PVC.
ptfd1819
14 Aug 2008 09:34 PM
what did you find made the best transition?
i was thinking going with a threaded connection
Alton
Have you looked at Speedfit push-in fittings by John Guest to connect different types of pipe?
Membership:
croccohvacusa
People Online:
