Not sure how you can determine which you have. Any chance of asking the installer?
You can not mix them!!!!
Methanol
water has a low frictional pressure drop and a relatively high heat
transfer coefficient. However, it is highly volatile, highly flammable,
and highly toxic until diluted. Low cost.
Propylene glycol solution is an alternative with the only true
advantage of being less toxic than methanol. Below about a 20°F
freezing point, the viscosity gets excessively high, resulting in high
pumping costs. High cost.
