Horizontal ground loop,right direction?
Last Post 03 Sep 2008 10:47 PM by joe.ami. 2 Replies.
powerboatmanUser is Offline
03 Sep 2008 07:05 PM
Hello All,
  I'm installing my first geothermal system at my home in southwest Ohio. The time has come to install the horizontal loop, and I want to run the figures by the pros to see if I'm on the right track. The heat pump is a Trane Axiom GEHB048 4 ton, the flow rate 12GPM, single pipe in trench at a depth of 6 feet in damp silty clay. My Wright Soft trial S/W says I need 1200 feet of 1 inch SIDR 9. I have 2100 feet of 1 inch available, and was thinking of running two loops of 1050 feet each (parallel operation). Am I in the right ballpark ? Will additional pipe be a worthwhile investment ? I have 10 acres to spread the pipe out on, so no problems there.
Thanks for the review. Dave S.
03 Sep 2008 10:08 PM
Good loop design generally gives one parallel path per ton. More pipe is always better, but the payback diminishes.
What does Trane suggest? Go with that and be safe.
J
People Online People Online: Visitors Visitors: 793 Members Members: 0 Total Total: 793
