BORE HOLES
Last Post 26 Sep 2008 06:52 AM by geodean. 5 Replies.
woolfskiUser is Offline
25 Sep 2008 04:43 PM
1.  How do I verify the depth of the bore holes for closed loop GEO system?
Bill NeukranzUser is Offline
25 Sep 2008 05:00 PM
There are some inspection points that will allow you to easily verify the depth of your bore holes:
The pipe will be delivered / brought to the job site already cut to match the depth of the bore holes (see first image below).  Look for some kind of tag / paper work indicating the pipe is the correct diameter / length.  Illlustrated here is 1" HDPE U-Tube pipe at 300' per roll (600' down + back).
After each hole is drilled, you can observe the pipe being inserted into the hole (see second image),
and verify that all of the pipe is inserted (third image).  Here it shows what was left hanging out of the ground for each 300' spool.
You can also verify the holes are being drilled to the proper depth by counting the number of 10' drill rod segments on the drilling rig.  There were 30 on the rig in the second image.
Hope this helps.
Attachment: IMG_9214.jpg
Attachment: IMG_9224.jpg
Attachment: IMG_9284.jpg
25 Sep 2008 05:04 PM
1.  Is there a way to verify the depth after the tubing is installed?
25 Sep 2008 09:13 PM
depending on the brand of pipe you bought, some have the footage printed on the the pipe in 2' increments.
WEL0058User is Offline
25 Sep 2008 10:36 PM
Dewayne,
I believe that Woolfski wants to know the length of the boreholes after trenches have been backfilled.
Bob
Posted By rgausman on 09/25/2008 10:36 PM
Dewayne,
Bob
If that is the case,  then he is out of luck.
People Online People Online: Visitors Visitors: 518 Members Members: 0 Total Total: 518
