Geothermal Heat Pumps
ground loop
Last Post 28 Sep 2008 09:38 PM by
geodean
. 5 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
brodies
28 Sep 2008 11:57 AM
I am having a system installed in some very rocky soil. 3 ton unit 400 ft trench 6' deep with 4 800 foot loops. Just curious what happens if one of the loops get kinked by a rock over time or if it is to happen would it happen right away. I am pretty sure they will be bringing in some sand to bed the returning loop. how tough is the pipe.
Palace Geothermal
28 Sep 2008 12:25 PM
HDPE pipe is soft plastic. It is quite durable, but can be damaged. Small round rocks (the size of baseballs) are not much of a problem, large sharp rocks can easily cut the pipe. Steps should be take to protect the pipe.
brodies
28 Sep 2008 03:32 PM
with a 6 foot deep trench rocky soil how important is the two foot seperation between the supply and return loops is depth more benefical or the seperation. Will the return or top loop cool the bottom loop if it is to close say 16"
Palace Geothermal
28 Sep 2008 03:42 PM
There is no compelling reason to separate the supply and return by two feet vertical. If you keep them to either side of the trench you will be fine. We have installed 100's of loops and this is what we do.
brodies
28 Sep 2008 07:00 PM
the 8' wide trench has four lines in it seperated 2' apart. if they were to run the supply lines back next to each other there would less than a foot apart. Therefore they are seperating the lines verticaly rather than horozontialy. Is a foot to close vertical or horizontal?
Palace Geothermal
Posted By brodies on 09/28/2008 7:00 PM
I think that a foot separation is OK.
Membership:
croccohvacusa
People Online:
