1) My opinion is as long as you maintain required GPM, the heat pump doesn't care. If water is standing in basement for a time then it could cause nominal benefit in the winter and cause nominal loss in summer; wash. 2)When you ask about wells, I presume you are referring to an injection well. Won't emabarrass myself (as I often do here), I'll defer to the moles (drillers). Good Luck, Joe |
