Crusher rock is not neccesary for this installation. If the pipe is laid in small trenches, it is best to start filing the hole with shovel to cover up the pip[e before using a machine. If it is a large pit, a backhoe could still work to backfill the hole. The proper way to backfill is to start where there is no dirt, and make it slant into the area where the pipe is laid. This method allows the dirt to fall easier onto the piping instead of straight down. Additionally, dirt on the bottom of the pit is not a bad thing, just be sure there are no large rocks or sharp rocks as you do not want to puncture the tubing from dropping rocks on it.
