Posted By engineer on 11/21/2008 8:23 AM
To understand the increased power in heating mode consider these things:
3) Higher temperature condensing means higher refrigerant pressure, which means higher compressor power. The observed increase in compressor discharge temperature supports these observations. Discharge temp is the sum of saturation temperature plus superheat both carried in from evaporator and added by compression.
BTW - that 155 compressor discharge is most excellent for desuperheat / hot water generation, even though it somewhat detracts from system's space heating capacity.
This is very helpful - much appreciated.
I can understand point 3 above. My compressor is operating with it's R410A refrigerant at a higher pressure in heating than in cooling mode. Thus, it makes sense that current draw has to increase - the compressor is working harder.
With respect to the DSH: Last year I turned it off during cooling mode after figuring out how poorly it performed (thoroughly discussed in other threads - not looking to discuss it here). I left it off during the heating season, reasoning, without data though, that it probably similarly poorly performed.
During this year's cooling mode, after further study (again, well discussed elsewhere) I turned the DSH back on. Being curious to see how it actually performs in heating mode, I've left it on.
A key new learning already for me is the substantial increase in compressor discharge temp. I didn't know, even with an R410A system, the amount of 'headroom' available to heat domestic hot water (DHW) would increase so much (for me, from about 120° to about 155° - 3 ton, 1st stage unit).
For this Winter I have a monitor set up to track the total energy required to provide DHW, and the portion of the total supplied by the DSH.
For this month so far the portion is only 2%, but that's not surprising. We're in this 'in-between period' going from Summer to Winter, where we run little HVAC, cooling or heating, at the moment. The month of Jan., being our most intense heating month, should illustrate best possible DSH performance.
Many thanks again for the instructional comments.
