Over the weekend my family was complaining about being cold. Unfortunately I think it was humidifier problem which I'm working on resolving. To help with the complaints I bumped the heat up 2°.
My question involves the operation of the unit. When the unit was installed a
Honeywell TrueZone was installed to handle the new zone for the basement. If you look at the front panel there are lights for cooling, heating, fan, purge and EM Heat.
In the summer with the AC, the fan would start in Cool 1 and eventually slow and switch to Cool 2.
So far this heating season I've been seeing the system in Heat 1 all of the time until this weekend when Heat 2 and Heat 3 were lit. The fan seemed to be blowing just as hard as it did when operating in Heat 1. Are these lights not indicating which stage the fan is operating in?
My temp setting is 68° from 4 PM to 5 AM. At 5 AM the temp goes up to 70° so the house is warmer when everyone gets out of bed. This morning at around 6 AM I noticed the thermostat was indicating AUX HEAT. The house was 70° and the exterior temperature was 30°. Should the AUX HEAT (which I assume is the heat strip) be turning on for a 2° increase on a 30° day? I was awake at 4AM and heard the system kick on. It ran constantly until I got up to get into the shower at 5:30. It was still running at 6 AM when I noticed the AUX HEAT.
I have a
Honeywell Thermostat controlling the system.
Thanks for the help.
