Posted By snowaway3 on 12/06/2008 12:31 AM
hey thanks for your input. My heat loss factor ranged from 80000 to 97000. u think 4 ton will do or would 5 tons be more effiec. I know there are many factors to consider but in general. we do burn some wood in a high effiec. insert
A 4 ton at best will only give you 55,000 btuh at 50° EWT. If your EWT is 30° you will only get around 40,000 btuh. What kind of loop do you have?
