ct- westchester contractors
Last Post 28 Dec 2008 04:14 PM by Paul Auerbach. 3 Replies.
jpmcabeUser is Offline
26 Dec 2008 02:10 PM
Anyone have experence with any good geo contractors in the Stamford, Ct area.
I am considering one from across the state but am a little worried about future service- about hour and 15 away. They do have service plan but seems to far to get good service if really need it- freezing cold in the middle of the night.
geo fanUser is Offline
26 Dec 2008 02:33 PM
check your private messages
Scott9345User is Offline
26 Dec 2008 03:12 PM
I had AMX heating and cooling out of Pleasantville NY install my 5 ton system.  PM me if you need any info.
Paul AuerbachUser is Offline
Check out www.totalgreenus.com.  We are a highly experienced DX geo designer/installer in Orange County NY.  We work in Connecticut and would be pleased to estimate your job.   We have dozens of very happy clients throughout the Hudson Valley and Catskills.
Since you are renovating you can control insulation - which makes a great difference in the size of the system required.  You should do TWO systems - upstairs and down.  It will work better in the long run and for the additional cost (adds about 10-15%) is well worth the money.
Just based on square footage - and with proper insulation (we recommend foam because it air seals as well as insulates) the heat load should come in at about 60,000 BTU/H give or take 10%.  The cost for a high quality DX installation should come in the upper $50's to low 60's - depending on complexity of the HVAC component.
Regarding service - generally geothermal installers work with local HVAC - who handle the service - which for the most part is unnecessary if the system is set up right to begin with...
If you would like to talk about geo in general - feel free to contact us.
Paul Auerbach
Managing Partner
Total Green LLC
cell: 845-234-5002
ofc:  845-774-8484
People Online People Online: Visitors Visitors: 206 Members Members: 0 Total Total: 206
