adding a ground loop
Last Post 02 Jan 2009 10:01 AM by geodean. 3 Replies.
snowaway3User is Offline
02 Jan 2009 04:32 AM
I have a 3 ton geothermal unit in my house and need to have a 4 ton unit. my ground loop system is for a 3 ton unit and is 3 horz. loops. can i add a slinky loop off the header or can i add on to the end of the last loop. thanks
02 Jan 2009 08:06 AM
Probably off the header
Eric DUser is Offline
02 Jan 2009 08:26 AM
Snwaway3,
How long has the 3 ton unit been in operation? What changes have happened that requires a larger unit? The reason for asking, is the current loop not keeping up where adding to the loop might allow the 3 ton would allow it work better?
Regards,
Eric D<br>Southern Michigan
not off the end of the last loop.
People Online People Online: Visitors Visitors: 122 Members Members: 0 Total Total: 122
