actually the skin is always moist , you sweat constantly it usually just evaporates , how much you sweat depends on your body's temp and has a direct relation to how quickly your sweat is evaporating , so to recap when your sitting on the couch and its 65 degrees and you haven't moved all day , your sweating . this drawing humidity from your skin will make you cooler and will show itself with bloody noses , dry skin , chapped lips .
This is why controlling latent heat is so critical to comfort
See heat index if you dont trust
